Use of the sw1/2 and reset button
  • My electrician and I wonder if we have to use the sw1 when the Shelly pro 1 only will be used to pwer on and off? As in the connection diagram for Shelly Pro 1PM "Device control and monitoring".
    And another qestion, can the reset button be used to power on off manually?
    Sorry, its urgent as the electrician is still here.
  • You may leave the SW pin open if you don't use it. But you must ensure the shelly is switched on: This can be done by setting "Auto On, if device is powered".
    The reset button should be used for resetting purposes only. It does not power the device off or on.
  • Hi thgoebel,
    Thank you very much for the answer. I really appreciate the recommendation of "Auto On, if device is powered".
    But I can't find where it should be done - in the menu.
  • Here a view with the Shelly App:
    …and a view with the WebGUI:
  • Hi,
    Fixed! I have Shelly app on my huawei mobil - Shelly app, but is there a shelly cloud app for windows? Where to find?
    I found the Shelly Pro 1 via ip (on lan), but looking into the settings the ip is "Null". Trying to set fixed ip I got the answer "Not a valid netmask format".
    Up and go, but the power comsumption don't work. What can be wrong? Se picture. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
