External Switch (Garage) not changing states
  • I have configured a Shelly 1 to control my garage door and wired the Shelly 1 switch in series with a reed switch (NO) to Gnd using a 24 VDC power supply from the motor controller.
    1. Button type: Detached Switch
    2. Power on default: Off
    3. Timer: Auto Off after 2 sec.
    4. Input state: ON (and this woks correctly showing the reed switch closed/open)
    5. Appliance type: Relay
    6. External Switch: Enable/Garage
    7. Firmware Version: 20220209-092750/v1.11.8
    The issue is that the display shows the garage door always open or closed if I reverse it. The Power Button Input State will show the correct colors. I set it up green when closed and red when open, but the door icon never updates
    Any suggestions? or is this a firmware issue?
  • Welcome to the forum, Nico!
    The issue the TE had was, he didn’t use an Add-On, but had configured that („external switch“). Thus, he didn’t get the expected reaction…
    Use an Add-on and get success…
