Shelly 1 - Ventilation system - Vasco DX4
  • Hello all,
    I want to wire up my Ventilation system. In the manual i find a way to connect a Niko type 170-45900 switch.
    The screenshot of the manual is in dutch. It is saying:
    L1 & L3 closed - Highest
    L1 & L2 closed - Middle
    L1 open - Lowest
    Is it right if i wire it up like this?
    So when
    01 & 02 are off -> Lowest power
    01 on & 02 off --> Middle power
    01 off & 02 on --> Highest power
    Thanks
  • Your diagram shorts permanently pins L1, L2 and L3. Thus, functionality has gone…
    Due to the fact, you want to control 4 possible states: O=off, 1=low, 2=middle, 3=high, you need at least two dry contacts and a central on/off switch. But the Shelly 2.5 doesn’t have dry contacts!
    I would recommend
    (A) a Shelly pro 2 (two separate dry contacts for the intensity) and a Shelly pro 1 (to switch the ventilation on/off), or
    (B) three Shelly 1 (two for the intensity, another to switch on/off).
    (A) has the merit to be mountable on a DIN rail - but is more expensive than (B).
  • True, i totaly missed that... My bad.
    Actualy with the 3x Shelly 1 u mean wire it like this?
    I don't want to add a DIN rail to the place thats why i try option (A)
  • If live potential has to be connected to pin L1 to turn the ventilator on, your sketch is fine! But I would recommend to wire the „I“ terminals of the Shelly in the middle and in the right to L1. Don’t know what happens if L2 and/or L3 are powered without powering L1! With my recommendation, you would avoid faulty situations…
  • I don't realy get what u mean, i'm very new to this :-)
    You mean this?
    Is this a dry contact?
    Or do i have to remove the "I" from the first shelly?
    The manual doens't say anything about dry or live contacts...
    Einmal editiert, zuletzt von Warierke (28. Juli 2022 um 17:12)
