PWM input for Fan (Using RGBW2)
  • I am looking to purchase this 2 of these fans for both my remote kitchen exhaust and also my Makeup air, and would like to control it via Shelly devices.
    But looking at the manual it seems that PWM (0-10v) is available for the speed control.
    Could I use a Shelly RGBW2 as a fully variable control for this via PWM? From my checking of the manuals this seems to be pretty straight forward..., I assume I could even skip the "ground" as the fan is already powered and this is just providing the input
    Bottom left diagram is what I am thinking.
  • There‘s a good chance for a success! Did some months ago nearly the same with a BELIMO servo drive:
    thgoebel
    31. Dezember 2021 um 15:18
    An additional resistor between 0-10V input and plus 10V (or 12V) will be necessary.
  • Thanks for that thgoebel thats really good to know.
    It would be really great to have more support for a product like this, I am finding a lot of consumer devices running the controls of 0-1v. (I am used to it at work in the industrial sector where 0-10 or 1-24v is common)
    I tested this for a project a year or two ago, you will need to add a protection diode for the Shelly, protect against back emf from the motor.
    You should also be aware that the shelly switches the ground not the supply so you have to change wiring to accommodate this.
    It does work, speed control is fully variable and very granular.
    There is another issue but it might not be a problem for your application, the PWM is set at 960Hz and this means the motor is very noisy with this frequency, like a loudspeaker, especially at slow speeds.
    The chip used in the RGBW2 can't run faster PWM, I have a feature request lodged for when/if they release an RGBW Plus based on the ESP32 that they have a motor mode where PWM is set to 32kHz which EPS32 can do.
