Detect movement of gate motors with Shelly Plus 4i
  • Hello,
    Is it possible to detect if gate motors (swing gate) are being powered with Shelly Plus 4i? When I connected it to the motors phase wires it was constantly showing as on and the device was getting hot. But the phase detector was not showing current being supplied to the motors. How could this be achieved so that I could sense with Shelly Plus 4i when the motors are running?
    • Hilfreichste Antwort
    This could be done with
    (a) a relay to separate the motor coils from Shelly’s input, or
    (b) the black optocoupler gadget which is delivered with Shelly RGBW2, or
    (c) a resistor of approximately 500kΩ to 1MΩ in series to Shelly‘s SW input.
    Some details, especially for solution (c) are described here (unfortunately in German language):
    thgoebel
    2. September 2021 um 18:57
  • adorobis 25. Juli 2022 um 21:28
    Hat einen Beitrag als hilfreichste Antwort ausgewählt.
  • (c) a resistor of approximately 500kΩ to 1MΩ in series to Shelly‘s SW input.
    thgoebel
    This option seems the easiest and the most convenient to implement.
    I have one question though: Those gate motors have 2 phase cables (for two directions) so detecting on N is not giving me the required information. Will putting the resistor between the L input of the motor and input of the i4 work ok? Or it will only work on N switching?
  • You’ve two options:
    (a) Setting „reverse Inputs“ for each channel turns the logic to the appropriate behaviour.
    (b) Swapping the two supply Leads of the Shelly plus i4 (live wire to terminal N and neutral wire to terminal L) does the same.
    Feel free to make a choose!
    BTW: If you have an issue to get the parts or a ready-to-use resistor, please drop me a message!
