Wiring help for stairway / hallway light (two switches)
  • I am struggling to find the right way (if possible) to wire a single shelly 1 device to correctly control my hallway lights which are operated using two switches.
    I have included a wiring diagram of my set up.
    I have seen other posts suggesting to place the shelly above the light but this isn't possible with my setup.
    Any help would be appreciated! Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
  • Der Inhalt kann nicht angezeigt werden, da er nicht mehr verfügbar ist.
    Your wiring diagram is wrong!
  • In the (rare) case you don’t want to change your wiring, you may use this diagram:
    But you will need a Shelly 1L and - if your lights have a wattage of less than 20W - an additional Shelly Bypass. Please be aware that live potential is connected to pin O of Shelly 1L and the lamp wire to pin L! This is correct and was tested. The bypass should be wired in parallel to the lights (perhaps in the ceiling rose)…
    2 Mal editiert, zuletzt von thgoebel (29. Juni 2022 um 13:54) aus folgendem Grund: First diagram was wrong (sorry!).
    Hey 66er!
    Thanks for the input! The diagram itself is correct. I have also attached a picture of the wiring behind one of the switches (both wried in the same way). I have checked using a screw driver tester as I've flipped in the switches (on on, on off, off on, off off).
    Any suggestions on if it's possible to wire a Shelly 1 given the set up?
    Looking at your link, the economical two way switch looks the "closest". The way I understand it, is taking the output (black wire in my case) from one of the switches to a Wago. Then adding 2 wires to the same wago, one back to the swtich again, and one to output on the Shelly.
    Thanks for the help so far!
