Double Switch (Hotel Switch arrangement)
  • Hi folks!
    In my apartment I've wired up 5 Shelly 1PM's and a Shelly 2.5 for the lights in almost all my rooms. I've got one Shelly 1PM left to go, for my hallway lights and they're configured in a hotel switch arrangement (not sure if this translates well, we call it a "hotelschakeling" in Dutch), where two separate switches operate the same light.
    I have seen wiring diagrams for this type of arrangement on a Shelly 1, but I'm not a 100% sure if I can blindly use that, since the Shelly 1 has dry contacts.
    Here's the situation (sorry for the crude drawings):
    One switch has a Live, switching into two separate wires of which one is always connected to live, both feed into the second switch, which has one output, going to the lamp. That second switch is where the Shelly will go (there's also Live and Neutral available from the adjacent wall socket).
    Externer Inhalt i.ibb.co
    No the following are quite clear:
    O - The wire going to the lamp
    SW - The wire coming out of the switch (it'll be under 220V if either of the switches is ON)
    L - The live wire from the adjacent wall socket
    N- The neutral wire from the adjacent wall socket
    I'm only wondering about L1 really. Do I just split the Live wire and plug that in there too? Like the following?
    I'm just not entirely sure that makes sense.
    Thanks in advance for your time and effort!
    (I'm aware the switch needs to be configured as an edge switch)
  • With Shelly 1PM, terminals L and L1 are internally linked together. There's no obligation to connect both terminals to live wire.
  • Aaah, that's brilliant, so I can just leave L1 empty? Saves the trouble of fumbling a Wago into the wall box, haha.
    Thanks for your quick reply!
