2 wire light install – have I bought the wrong Shelly?
  • Bit confused with this light switch, I was expecting more wires, but instead I've only got two :)
    Black L, brown N, so I can get the Shelly to power up OK.
    I can also get the Shelly to recognise the switch input, as wired in the attached photo.
    I'm having a mental struggle trying to figure out how to close the loop with the relay (so that the lights work).
    Thanks, D
  • Hi and welcome to the forum. :)
    Shelly1L should be used, Unfortunately currently not available.
    Your installation is missing N at the switch. ;)
  • Indeed - in this case you’ll need a Shelly 1L, and possibly a bypass. You should wire the Shelly 1L according the following diagram:
    277-ar768-wechselschaltung-ohne-n-bypass-v2-png
    Please forget the second switch shown in the diagram! Connect pin L of your switch to pin Sx of Shelly 1L and the arrow pin with pin SW1 of Shelly. If your bulb has a wattage of less than 20W, you’ll need an bypass too.
    Addendum: Sorry - was too slow (or have used too many letters). @66er reached the goal at first…
  • Update ... possibly figured it out ... install the Shelly here, instead of at the switch. The two wires from the switch connect to L and SW on the Shelly, then figure out the rest ;)
