Shelly 1L tripple switch
  • I have a bit of a 'complicated' setup and couldn't find an answer to my query yet. Hope someone can share some ideas.
    Light bulb(s) connected to 3 switches. Looking to put a Shelly 1L inside the middle ('intermediary') switch seems like the easiest route (below in red), in terms of effort and space to fit in the shelly relay.
    As per the diagram, L1 and L2 can be live input & output depending on the situation.
    So I am basically trying to replace the physical button ('intermediary' switch in the scheme above) with a software one (Shelly app), while still allowing all physical button to continue operating as usual. Which I think (hope?) is possible.
    Still cannot figure out what Shelly ports should I connect 2 in and 2 out wires and what mode should I set the ports to.
    Thanks,
    Milen
  • I think I have a solution but can't test it.
    But it would be easier at the first switch .
    Here's the idea
    At first switch
    Remove Phase and Black from switch
    Connect them (so will be Phase at switch 2)
    At second switch
    Brown needs to be split in two
    - one at SW1 the other at SW2
    Black from first switch at L from Shelly
    O from Shelly at the Grey (Left side from switch)
    Button Type edge
  • IMHO, this would be quite simple:
    Shelly 1 (Shelly 1L not necessary, but applicable) arranged in box with SWL/L/N.
    SWL connected to SW of Shelly.
    L to pin L and I of Shelly.
    N to pin N of Shelly.
    Lamp wire (previously at SWL) to pin O of Shelly.
    Button type: Toggle or Edge
    Hope this helps…
    2 Mal editiert, zuletzt von thgoebel (5. Juni 2022 um 11:12)
  • Thanks for your advise SebMai, but that wouldn't that render switch 1 redundant? I'd still like all 3 switches to operate, but also have the software control as well.
