Shelly 1L with a doubleswitch
  • Hi,
    Is that possibly to connect a Shelly 1L to a doubleswitch? I have a doubleswitch that goes to two different lamps.
    Is that possibly to have one of this lamps "smart" and the other one work as normal, only with the switch?
  • Welcome to the forum, tommie73 !
    In the ‚lexicon‘ section of this website, you’ll find tons of diagramms. I.a. this one:
    This diagram corresponds IMHO perfectly with your issue: Two lamps and a double switch - and (assumed) no neutral. Please pay attention: Live wire and wire to the lamp are swapped at Shelly‘s terminal block! This is correct and was thoroughly tested…
    Einmal editiert, zuletzt von Admin (16. Mai 2024 um 11:45) aus folgendem Grund: Bild wegen Markenrechtsverletzung gelöscht
