Schelly 1pm schaltet einfach nach 6 Minuten aus
    schelly 1pm schaltet einfach nach 6 Minuten von alleine aus. Ist in der Cloud und keine Timer etc. programmiert. Kann jemand helfen?
    {"wifi_sta":{"connected":true,"ssid":"FBTT(2,4GHz)","ip":"192.168.178.83","rssi":-65},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"07:37","unixtime":1652593027,"serial":14,"has_update":false,"mac":"E8DB84D44239","cfg_changed_cnt":1,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"source":"cloud"}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1652600227,"counters":[0.000, 77.620, 77.758],"total":547}],"inputs":[{"input":0,"event":"","event_cnt":0}],"temperature":42.82,"overtemperature":false,"tmp":{"tC":42.82,"tF":109.08, "is_valid":true},"temperature_status":"Normal","ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"idle","has_update":false,"new_version":"20220209-094317/v1.11.8-g8c7bb8d","old_version":"20220209-094317/v1.11.8-g8c7bb8d"},"ram_total":50456,"ram_free":35880,"fs_size":233681,"fs_free":132026,"uptime":528}
  • Die „uptime“ ist mit 528 Sekunden sehr niedrig! Bitte überprüfen, ob das bei jedem Ausschalten so ist? Dann muß der Grund für den reboot gesucht werden…
  • Tippe, hier wird eine induktive Last geschaltet.
    Beim Schaltvorgang startet der Shelly neu.
