How to disable the switch feature, and use only the power mettering
  • Hi to all, greatings from Portugal
    I'm a newbie in home automation and in Shelly. I have a Shelly 1PM whose function is only to measure the consumption of that installation, in this case, all the computer equipment in my office. Turns out, the APP appears the button to turn on and off, something that I do not want to be done, because it will turn off all computer equipment. Is there any way to configure shelly 1pm to just serve as a consumption meter without any kind of button?
    Thank you in advance
    Stay Safe
    Antonio Ferreira
  • Hi and welcome to the forum. :)
    You don't need to connect sw.
    In the app, the switch is always to be seen.
  • Some people tie SW to L to get double certainty. And the settings could be configured to switch relay on when power is applied...
    Hi 66er, thank you for your reply and help,
    i don't use the SW connector, only O, L and N, but in the app, if I inadvertently touch the button, the switch is activated and the power is turned off, that's i want to prevent.
    regards
    Hi thgoebel, thank you for your reply and help,
    and with this settings i can't turn it off ? if yes, it's a way for my problem
    regards
