No voltage on O I ouputs on shelly1
  • Hi all.
    i have Shelly 1, i connected it to 12V power supply, move the jumper and add a light source (12V 20W) on the O I outputs.
    i manage to supply the device with 12V, than i connect to the web interface, when i flip the switch im hearing a click sound ( i thing this is the relay ) im seeing on the web interface that blue circle around power button lights up, but the light source is not turning on.
    i also click a few times the power button that is in the web interface, hearing clicking sounds again but still nothing.
    than i get my multimeter and put the probes on O I and i did not get any readings.
    i connect the light source directly to the power supply and it lights up but when is connected to the O I pins it does not.
    Could someone help
  • Welcome to the forum!
    The relay contact of Shelly 1 (between terminal I and O) is a „dry“ contact! Hence, you’ll have to wire terminal I to +12V, one leg of the lamp to terminal O and the remaining leg of the lamp to -12V/GND. Have a look at the ‚lexicon‘ to find more diagrams!
    Hi.
    Thanx for response.
    Do you mean this diagram ?195-ar768-ausschaltung-png
    Cause i currently use this one
  • If you alter the (first) diagram found in lexicon mentally from mains supply to 12V DC supply (N equals +12V DC, L equals GND), you may use it! The second diagram describes the implementation of a potential-free („dry“) contact in an unknown environment - nobody knows where the two green wires are leading…
    Thus, adopting my tales in post #2 with terminals I and O to second diagram, it is applicable.
    Einmal editiert, zuletzt von thgoebel (5. Mai 2022 um 10:06)
    Thank you.
    I manage to make the connections.
    Now when i flip the switch ON, im hearing how the relay is clicking repeatedly without stopping and the light is still not turning on.
    2 Mal editiert, zuletzt von bobi00 (5. Mai 2022 um 11:00)
