Dimmer 2 with Single Momentary Switch
  • Hi all,
    I am looking to wire up my house with a series of dimmable downlights and my goal is to have each bedroom illuminated by four downlights and single Dimmer 2 with a single momentary switch. I have read through the instructions and understand that my home is looped at the switch with a neutral wire both at the switch and at the light. According to the manual I will need to wire my Shellies as standard wiring with neutral and SW connected to neutral. However what I don't understand is which button type to select as well as program the momentary switch to turn on, turn off, and to dim?
    Any advice you can provide will help me greatly.
  • For one button momentary switch operation you‘ll have to configure „one button mode“ in „settings/button type“:
