How to update the firmware of a Shelly Door Window 2 ?
  • Hi,
    How to update the firmware of a Shelly Door Window 2 ? On the web interface of my shelly door, it says I can update and so I run it. But nothing happens. I get back this message:
    Does this has to do with the sleep/wake up of the device ? How can I wake up the device ? It's speaks about the "button", but I don't see any button on the device.
    Thanks
    Fred
  • welcome to the forum :)
  • Yes,
    please have a look here:
    (German thread)
    Gast10
    14. April 2020 um 11:56
  • It seems that when sensor has access to home network and user can access embedded web interface via access point, then firmware update works without any need for "proxy" etc.
    Therefore I succeeded by following the procedure:
    1.Start with factory reset = unplug batteries, plug batteries back and press and hold smaller hole for 10 seconds (se User and Safety Guide and Press and hold the button for 10 seconds for Factory Settings Reset. Successful factory reset turns on the LED indicator to flash slowly.)
    2. Then with computer, connect to (opened) Wi-Fi network shellydw2-<last-6-characters-from-mac-address> and open the default web page http://192.168.33.1/
    3. In Internet & Security check that CLOUD` is enabled.
    4. Then in WIFI MODE - ACCESS POINT configure some dummy password for another Wi-Fi network shellydw2-<all-12-characters-from-mac-address> and press CREATE Access Point
    5. Connect computer to this Wi-Fi network `shellydw2-<all-12-characters-from-mac-address>` and again open the default web page http://192.168.33.1/
    6. In WIFI MODE - CLIENT connect the sensor to your home Wi-Fi network and press SAVE
    7. Finally go to Settings, choose FIRMWARE UPDATE, press CHECK FOR NEW FIRMWARE and upgrade device.
    Note: now you can delete on computer remembered Wi-Fi networks `shellydw2-<last-6-characters-from-mac-address>` and `shellydw2-<all-12-characters-from-mac-address>`
