shelly 1 - min and max input voltage
  • Hi, I couldn't find relevant info anywhere - what are the voltage ranges for shelly1? I have 12V DIN PSU with variable voltage ranging from 10,5V-13,8V. I've tried 13,8V and so far shelly is working, but is this sustainable or will I fry it over time? Thanks for any info
  • 10,5V to 13,8V DC is within the secure range. Would not recommend to use more than 14,5V…
  • Same question: I would like to use Shelly 1 in my car... But when it chargibg from generator (in working engine) it is above 14 VDC (14.3, 14.4 Volt)...
    Could I use it for? Or is there any (other) solution?
  • Would not recommend to use more than 14,5V…
    Hence, with 14,4V you’re still in the secure region… :)
    No kidding - you‘ll find some (not very much, but some) examples in the forum where a Shellies were used in a car. Give it a try!
    You may use a diode (1N400x; x from 1 to 7) to add 0,7V more electrical strength. Arrange the diode in the lead for power to the Shelly 1 - cathode (ring) towards terminal N, Anode tied to plus pole of car battery.
