Pir sensor and shelly 1
  • Is it possible to connect a shelly (on 220V) to a pir (OMRON) sensor , which is powered seperately with 12V . The pir sensor has an output of 2 wires that are shorted or not.
    I want to use the shelly for this to see if the Omron sensor has been switched on and off ...and use this furtheron in my domotics controller.
    I possible...how would i need to wire this?
    Thanks in advance.
  • Did you think about powering the Shelly 1 with 12V DC? This is possible and the simplest way to couple the PIR sensor and the Shelly! Have a look at the forum‘s „lexicon“ to get more details!
    And, by the way: Welcome to the forum!
