Voltage on I at the same time as SW
  • Hi,
    so normally connection diagrams show that we connect L to L, N to N and L to I. Then when we have L on SW relay is closed and there is voltage from mentioned I(input) to O(output).
    I would like to have voltage on I at the same time when it appears on SW, so I has voltage only when SW(switch) is on and then and only then from mentioned I(input) to O(output). I know it wouldn't be possible to use for example command from Home assistant but are there any drawbacks of this solution?
  • A certain delay between the input pulse (at terminal SW) and the closing of the relay contact will be inevitable - due to the fact a CPU is the intermediate part between both terminals. In this thread you’ll find some oscilloscope graph showing delay times (unfortunately in German language):
    thgoebel
    7. Februar 2022 um 15:33
  • Thank you,.
    I have also done some tests and SW is preloaded with ~127V (I think because it is possible to use N to swich ON).
    Because of that, after switching OFF, connected bulb is still halfway ON.
  • Did you connect the input SW at an existing switch - bulb circuit? If this true, you’ll need
    (a) an intermediate relay, or
    (b) the optocoupler device which is delivered with Shelly RGB2, or
    (c) a simple resistor (500kΩ - 1MΩ) as described here:
    thgoebel
    2. September 2021 um 18:57
    In some cases it would help to swap live and neutral wires at Shelly (especially when the bulb is a LED type).
    If you have an issue to get those MELF type resistors, please feel free to contact me via PM…
