Shelly EM Negative PF and Reactive Power - Highly inaccurate measurements?
  • Just installed a Shelly EM into my UK Consumer Unit. I have attached the 50A clamp around the incoming live tail.
    Voltage, Power and Overall consumption are all positive, but PF and Reactive Power are negative.
    The PF is consistently in the range of -0.67
    The power measurement is way off, I am looking at consumption measured by my smart meter and it is showing 415w, but the Shelly EM is reporting 281w.
    I have checked it is wired correctly, and even tried reversing the clamp. This turned the PF positive but the Power went negative.
    N.B. There is no solar or any other load I am aware of that would negatively impact the PF.
    Any ideas?
    Thanks,
  • Welcome to the forum!
    To your issue: Do you get one, two or three live wires out of the mains box? It is not very unlikely the current clamp is mounted on a live wire different from the wire the EM gets its supply voltage. Please double check the wiring!
  • With only one live wire it’s not possible to get the wrong phase. Too bad…
    Possibly you got a faulty Shelly EM or a faulty current clamp?!
