Shelly 1L with Candelabra
  • 2 of 5 lights in my candelabra remain on when the Shelly 1L is turned off, but are only dimly lit.
    I have a candelabra with 5 LED lights.
    I have fitted a bypass in the candelabra rose fitting
    * When I turn on the light switch the Shelly 1L relay clicks and all the lights turn on correctly.
    * When I turn off the light switch the Shelly 1L relay clicks 3 of the 5 lights turn off, but 2 remain dimly lit.
    Does anyone know if the Shelly 1L will work with Candelabras. The bulbs used are LED and the light fitting says each bulb should be limited to 42w
    Einmal editiert, zuletzt von soxprox (24. März 2022 um 12:52)
  • soxprox 24. März 2022 um 12:51
    Hat den Titel des Themas von „Shelly 1L with 12V regulated candelabra“ zu „Shelly 1L with Candelabra“ geändert.
  • Are the 5 LED lights of same type and power rating?
