I'm trying to use shelly 2.5 to open and close a sliding door that works with IR. The door plate schematic is as follows.
I connect neutral and phase and shelly works. I can connect to wifi.
When I connect opening (5) and closing (7) motor output in O1 and O2, the shelly app buttons don't work. I think it only works if I hold down the button on the infrared remote.
If I connect the output of the common motor (6) to the neutral (N) then the buttons of the shelly application work for me but not the button of the IR remote control, neither the opening or closing limit input (NC) works and I can't calibrate in the app.
My problem is that I don't know how to connect the shelly to the board when I have a common motor cable.
I had no problem with the blinds at home but this is more complicated. Can anybody help me?
