Heat pilot wire control ?
  • On top of controlling the whole electric on/off, is there a simple way to use the other ports port controlling the "pilot wire" for a heating ? In fact sending some specific electric pulse for most of the heating is pretty standard, and I am wondering if this can be achievable with this or another Shelly solution ?
    Thanks
  • Please try to give us some additional details!
  • Would propose to use two Shellies:
    (a) Shelly 2.5 generates the signals for „Off“ (diode at point A) and “Freeze protection” (diode at point B).
    (b) Shelly Dimmer2 generates the pulsed signals (minus 1°/minus 2°) via preprogrammed auto-off timer (point C). Dimming level should be 100%, because on/off function only is needed.
    Using a relay-equipped Shelly for purpose (b) would produce a continuous switching noise - not very comfortable…
    To generate the 3/7 second signal each 5 minutes, a home automation system may be necessary, if not to solve with scenes.
    Einmal editiert, zuletzt von thgoebel (21. März 2022 um 20:11)
