Shelly 1L not working without neutral
  • The connection you made fits the switch type: momentary
    Try to made connection for an switch type: edge
    See examples at the following link:
    If it will not be simple, it simply will not be!
  • Both methods to connect the switch should work!
  • The connection is working what suggested Efi Herman. Thanks. But I agree with thgoebel, it would be works with original plan. So I tested it with one lamp, and it worked. So I don't understand why not work with the first scenario.
  • I have another problem with Shelly 1L. I configured schedule to turn on automatically and turn off automatically in time. For example: turn on 19:00 and turn off 19:05. When turned off 19:15 the Shelly 1L disconnecting from the WiFi and cannot reconnect to WiFi. I have to turn on manually with switch to reconnecting again to WiFi. Why? Is that Shelly problem? How can I solve it? Thanks.
