Shelly Dimmer + light turn off above 40%
  • Hi all,
    Last week, i installed the shelly Dimmer at home. There was no neutral wire, so i put one.
    The shelly dimmer works, but i can only dim from 0% to 40%, if i go higher, the light turn off, after some time, the shelly dimmer is offline.
    Any idea what this could be?
    Dimmer is connected to 8 Led GU10 lights from Phillips (4.2 watt dimmable).
    Hello, and welcome to our forum ??
    Did you do calibration?
  • Yes, several times.
    One time it does a callibration, so you see the light dimmed low and going higher. Another time, calibration is failing so i have to reset the device.
    Perform the calibration via the Shelly Dimmer's WebUI not in the app. There you can see better when calibration is finished and successful.
    With Phillips GU 10 I would do trailing edge
