Cloud connection
  • Code
    Hallo
    A few days ago I bought a Shelly plug (3500W) to control the hot water boiler when I'm not at home on vacation.
    Now the connection to home network is ok but I can't connect it to the cloud it just keeps searching and can't stop it so I have to uninstall the app completely and restart it but connection to the cloud just doesn't work.
    Can you please help me.
  • Please check if you can see a time in the WebUi at the top right? If not, this indicates that the plug does not have internet. If you have set up via WebUi, bd assigned a fixed IP, please also enter the gateway IP of the router.
  • How did you try to enable the cloud connection? From the Webinterface?
    the initial connection must be enabled via Smartphone-App, just because the Device needs to be linked to your cloud account. This is not possible with the Webinterface.
