Shelly EM & Shelly Split core current transformer connector - Connector
  • Hi All,
    I have bought this from shelly UK https://shellystore.co.uk/product/shelly-em-120a/
    Do I need an extra accessory to plug the 4-pin connector into the EM device?
    I am tempted to just cut it off, strip the wires and connect direct to the Shelly EM, but I guess it is there for a reason!?
    There is no socket for this plug on the device I received.
    FYI, I am fairly familiar with Shelly devices, I have several Shelly 1, 1PM and Shelly Dimmer 2 successfully installed.
    Externer Inhalt i.imgur.com
    https://imgur.com/a/4sHK7io
    I have tried searching but found no relevant info on either google or on this forum's search tool
  • Current clamps for Shelly 3EM are equipped with a 4-pin connector, whilst clamps for Shelly EM have bare wire ends. IIRC, both types are not interchangeable.
  • Obviously! You should not be forced to cut factory installed connectors…
