Can't calibrate LED bulb
  • I have a Shelly Dimmer 2 that has been connected to a halogen 70W bulb and been working fine. I tried connecting a new 9W LED dimmable bulb, but when I calibrate it, it gets to 13% and then the bulb starts flickering and the dimmer2 loses power every time so it can't complete.
    I set it to Leading Edge and it managed to calibrate but then every time I switch it on it turns off after about 5 seconds and the webpage says "wrong calibration".
    I think it's sending too much power and overloading the bulb, though I am far from an expert. Is there a way I can manually calibrate or some settings to try? I fiddled with debounce settings but I don't really know what I'm doing, none of my other dimmers are attached to LEDs.
    Thanks in advance!
    Misha
  • Is the Shelly Dimmer2 connected with neutral wire? If not, you’ll need to connect a bypass in parallel to the load, cause the minimum load für Shelly Dimmer2 without neutral wiring is 20W.
