Shelly 1PM turning OFF when SW voltage is 0 - is it possible?
  • Is there a possibility or create a scene which will turn off Shelly 1PM device (and as consequence turn off water pump connected to Shelly 1PM) when voltage on SW connector is 0? And vice versa, when Shelly 1PM detects voltage on SW connector, to turn on Shelly and turn on connected water pump?
    Reason is because I can only turn on or off pump with Shelly Cloud app but I need also that pump is turned off when my heat pump (Daikin Altherma 3) is turned off (as it worked before Shelly 1PM installation).
    Thanks in advance.
  • Shelly 1PM relay is switched on, if current flows from terminal SW to terminal L. This means, if a contact is closed, which is arranged between terminal SW and L, Shelly relay is activated.
    Lesson learned: Shelly isn’t activated by voltage, but by current!
    Next lesson: The Shelly input may be inverted by setting “Reverse Input” in menu “Button Type”. This means, all the conclusions given in first section has to be inverted.
    Now you’ll have to revise your needs and make a new plan!
  • Thanks. The problem is that I don't have classic switch with two wires which need to be connected to SW and L. Meaning, my heat pump (as power source) has "switch" inside it and I connected live line (brown wire) from heat pump switch to SW terminal on Shelly. Water pump is connected to Shelly "O" and L1 to line and N to neutral. L connector on Shelly is not connected.
    So, when heat pump is disconnected, there is no voltage on SW connector but water pump is still running (until I put it off via application) and all connectors ("O" and L1) have voltage.
    I supposed that Shelly 1PM can be turned off or on dependent on voltage on SW connector with scenes. There is scene "when input state is off", so I assumed it is connected with SW connector.
    I am not sure how to have old on-off functionality and to measure power on my water pump or is it even possible?
    Scene "when input state is off" is for what? When this condition is met?
    Thanks,
  • Ok. Issue is clear: You want to activate a Shelly by a switch/consumer unit. In this case, you’ll have to switch the Shelly with neutral potential, which is given by the motor coil of the heat pump. Thus, activation of Shelly via live potential at terminal SW has to be inhibited, cause otherwise Shelly would be permanently activated (by neutral AND live potential). This inhibition can be done by a resistor of about 500kΩ to 1MΩ in series to the SW terminal. How this may be arranged is described here: Click! (Thread is unfortunately in German language. But you may use a translation app,,,)
  • Basically, I want that my Shelly 1PM is always ON (because it is also measuring temperature via temperature add-on) and to activate "O" only (water pump is connected to "O") when my consumer unit gives signal (voltage) which is connected to SW. Or vice versa, when there is no voltage/signal on SW from my consumer unit, this triggers pump tu turn off on "O" connector. Is this even possible?
    Basically, I connected switch and Shelly 1PM as in this video:
    https://www.youtube.com/watch?v=QGhhSu0e2uk
    where switch on the video is replaced by switch in my consumer unit. Wiring is the same. And it is working in video but does not work on my place.
    Einmal editiert, zuletzt von Stile (14. Januar 2022 um 23:13)
  • Dieses Thema enthält 52 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
