Send the status of the brightness in a DDD http Action?
  • Hello,
    How can I send the status of the brightness in a DDD http Action?
    E.g.
    {device2]/light/0?brightness={device1}/light/0/status.brightness
    What is the correct syntax?
  • Which Shelly type shall be controlled? Shelly Dimmer, Shelly Dimmer2 or Shelly RGBW2?
  • Sorry, I want to control with Dimmer2.
    The actual use case is to send Dimmer2 brightness data to Vera in one URL request,
    but I suppose the question is generic if you wish to synchronize other Shelly dimmers directly.
    Is there some way to include/extract the brightness value simply in a DDD action?
    Looking for a syntax.
    Evaluating a request before sending it?
    2 Mal editiert, zuletzt von Bobone (13. Januar 2022 um 15:04)
  • This (Click!) are the DDD commands to control a Shelly Dimmer2. But I assume you want brightness value FROM a working Shelly Dimmer2 to control other system? I‘m not aware of such an alternative…
