Can I use a Shelly 2.5 for two speed ventilator
  • Hi,
    I have a ventilator that can operate on two speeds. Matter of connecting the live wires to the correct pins. But I want to be able to use either speed without putting power on both connections at the same time, what would blow out the ventilator. So I need a relay. Is it possible to use the Shelly 2.5 for this purpose? If connection one is on, two is always out or both out but never both on? Thanks in advance.
  • Shelly 2.5 in roller mode does exactly what you want. But what is the power consumption of your fan in both speeds?
  • And Shelly can keep connecting? No confusion that the 'shutter' is still going up or down?
    Didn’t get the point exactly. What is the question? And yes - the Shelly 2.5 switches live potential via its two outputs to either one or the another terminal of the fan. It is ensured that both outputs cannot be activated simultaneously. In the WebUI or in the App the two switching options are represented as „up“ or „down“.
  • The thing is the fan runs as long as there is a connection. But if the Shelly can keep on 'moving up or down' it should work. As long as I can start and stop the fan as I please.
