Direct valve position control (e.g. for bleeding, etc.)
  • According to the API documentation (link), one can get the position of the valve (/thermostats/0, "pos" attribute).
    How can one directly SET the position of the valve (e.g. fully open or fully close)?
    Such a feature is needed for situations when particular valve positions (at least fully open and fully closed) are required regardless of the target and measured temperatures, for example:
    - when bleeding the radiators (the valve must be fully open)
    - if a pipe/radiator has to be replaced/repaired, or any other related activity (the valve must be fully closed)
    - when performing complete valve open-close cycles, in order to prevent it from becoming stuck/calcified/etc.
  • I wasn't aware of this functionality when I wrote my post, but it defently works fine. Already tested.
    When you disable automatic temperature control, the valve can be set in any position.
