turn on relay after power failure
  • Dear all,
    may I kindly ask how to configure that after power up the relays will be turned on. Example, I need to have relay1 and relay4 keep on after power failure. Whats id the way how to do it? Using script? if yes can you provide an example?
    Thanks
  • You may configure this in „settings“ per each channel:
    (Example with WebUI and Shelly 3EM)
  • Unfortunately, the WebUI of Shelly pro 4PM looks a bit different. But the appropriate settings are feasible:
    Have a look at the right side of the channel settings!
