Shelly 1L without Neutral but always neutral shown on wiring shemas !
  • Hi,
    I don't understand very well how the 1L is connected as in every shemas there is a link to a neutral somewhere...
    here i have a lamp to be managed by a scenario coming from another Shelly connected to a switch.
    this lamp has already a switch wired in the wall with only a L coming to the switch and the output going to the lamp. So, no neutral at all here in this switch.
    i will not need the switch anymore.
    can i do what i have drawn on this schema ?
    i could also avoid the bypas by wiring the neutral before the lamp directly to the N in the 1L ?
    and do i need a 1L ? because in the after schema i have both L and N close to the lamp, so a Shelly 1 would enough ?
  • Exactly! If you don’t need the switch (it must be closed to deliver „live“ potential to the lamp!) you may use a Shelly 1. Terminal N of Shelly to neutral/lamp, terminal O of Shelly to the other wire of the lamp, terminals I and L of Shelly to live wire from the switch.
    It would be brilliant to draw another sketch and to present it here for a double-check!
  • Perfect!
  • haha ok, thanks for so fast answer !
    but i have to say that i don't understand at all the wiring schemas presented usually !
    especially maybe for the Shelly 1, i think that the internal connections should be shown, then i could understand far better why we wire L and I with the same L, and why we wire O and N like this... and then Sw which stays to be understood !
    maybe i will understand one of these next days ... haha
    thanks anyway !
