Limited dimming range with Philips G4 bulbs
  • I replaced 9 halogen bulbs with Philips G4 2.1W LED bulbs (link), which say they are dimmable.
    I bought a Shelly RGBW2 with the intention to use it to dim these bulbs.
    While the bulbs say they use AC, the site I linked above says it can also take DC.
    I tested the setup with one bulb on my desk, with a DC lab power supply.
    I noticed that it was indeed dimmable, but only for a limited range.
    It started going dim when I dimmed the Shelly all the way to 40% and the bulb went off at 11%, so there is only about 30% dimming range.
    The bulb also didn't dim very much, even at 11%, before it went off.
    Is there a way to increase the dimming range?
    The Shelly works with PWM dimming, should I find another way to dim these leds?
    Einmal editiert, zuletzt von Nikotine (29. Dezember 2021 um 14:55)
  • Probably, 9 of these lamps in parallel would show a better behaviour? Would propose to do an extended test with all bulbs on the bench…
  • That's what I was thinking as well, maybe the load is too low?
    The specs don't say anything about a minimum load.
    I'll try it with all 9 bulbs in parallel.
    If that doesn't work, should I add a dummy load?
  • Don’t assume the load is too low - with the PWM Shelly RGBW2 is no minimum load existing! But the PWM duty cycle is limited itself. Thus more load (equals more current) could help to reach the optimal modulation range.
  • Ok, I installed everything and in fact it's even worse now.
    Dimming of the bulbs only happens now at about 20%, so the dimming range is even smaller.
    These bulbs are very hard to dim!
