Load on switch?
  • Hi all, Merry Christmas.
    I have a question regarding the Shelly 1pm.
    I am planning to switch a high load (12 A), and my question is regarding the load that goes through the switch, in order to make the right choice about it.
    Studying the diagram, I can not understand the load that goes through the switch. Is it just opening/closing a circuit by voltage difference, without any current going through, or will the 12A go through the switch?
    Thank you in advance!
  • Why did you chose a Shelly 1PM? Do you need energy metering? If not, you should consider to use a Shelly 1 or Shelly plus 1! Both types can switch 16A.
    But if energy metering is essential, I would recommend to use a Shelly EM and a contactor (relay). Energy metering with Shelly EM happens with a current clamp. Thus, a contactor can be used, with higher rated current as the tiny relay in the Shelly 1PM.
    And by the way: Welcome to the forum!
  • Hi thgoebel!
    Thanks for your response. I have handy here some Shelly 1's and some 1pm's. I prefer to use the pm's since they have temperature protection. Also, using a contactor is not an option for now, since it's for an old house and I would like to avoid removing the wires and adding more in the conduits, since most old houses here have broken in-floor conduits.
    So my plan is to switch this high load with the 1pm, just to have overtemp protection, and also use a switch I have handy. But it doesn't feel OK for me since I do not know the amperage that will flow through the switch. I don't know the rating of the switch I have here (it's just a normal lighting switch), so I am looking to find if it's safe, and also solve the question "what flows through the switching circuit in shelly 1 pms".
    Thank you again for your answer!
  • The rating of the relay contact of a Shelly 1PM is 16A @230V AC. So far, so good… The (manual) switch to activate a Shelly doesn’t guide the load current. Hence, the switch may be much smaller than expected. The switch has to be rated for mains voltage only!
  • That's what I thought, but couldn't find the info in the Shelly manuals. It is clear that the (manual) switch runs on mains voltage, but what goes through didn't seem clear to me.
    Thanks a lot.
