I bought two PM1 Plus at the same time and both are marked the same. Both are running 0.9.1 firmware. One shows power and voltage but the other only shows power. The Channel Settings are also different with one having a Maximum Current setting and the other lacking that setting. Did I get different levels of hardware or is there a device setting that is causing the difference?
