Help reading watts output photovoltaic panels 24V DC
  • Good morning,
    I needed help, as I will be able to connect a Shelly amp meter to obtain the power that the photovoltaic panels are producing. the energy that comes out of the panels is in DC 24v, I needed to know the watts it is producing.
    Attached I send my installation diagram.
    I hope you can help me
    Because I can get the watts I'm consuming, now I can't produce
    Thanks
    Sandro Guerra
  • NONE of the various Shelly types is capable to measure DC current or DC energy! Thus, your project will strand.
  • Additional question or remark on here, cause I believe this is may of interest for others as well
    sure looks like the provided clamps can only work with AC current due to a missing Hall Sensor inside.
    Anyway, why not attaching a clamp which is able to read DC current like some of these?
    https://www.amazon.de/PeakTech-Strom…s%2C101&sr=8-39
    As the DC Meassure out values are same, it should work, or?
    Its not a cheap solution but should work.............
    I will ask Official Support at Shelly also if this is a work around.
  • Brillant idea - but it will not work, cause the internal metering electronics of Shelly EM expects AC signals. Moreover, voltage has also to be determined! And the Shelly EM recognises AC voltages above some 95V only (due to the voltage divider resistors)…
    Einmal editiert, zuletzt von thgoebel (12. Mai 2023 um 08:24)
