Wont calibrate just flickers
  • I had a number of old style 60w bulbs used 2 in a 6 bulb rose and worked ok, but because 6 wont work (too much power) I purchased 6 4w Leds - now I just get constant flickering. They will not calibrate on either option and on attempt to dim they go offline. This is a no neutral setup without a bypass (as bypass not needed apparently for anything above 15w). Please help getting v.Frustrated, third set of lights....
  • Are you really sure the LED are dimmable? What brand is it, what type?
  • Obviously dimmable. But I’m sure you’re aware of the compatibility table for dimmable lamps? (Click!)This table lists issues with dimmable (they said…) lamps and Shelly dimmer/dimmer 2.
  • Please try to replace ONE of the 6 LED bulbs with one of the old 40W incandescent bulbs and give us a feedback!
