Why can't I get this working properly?
  • Hi All
    First post so go easy on me. Unfortunately it's a repetitive question regarding 2 way lighting.
    I watched a video on you tube from "Home Sight" regarding how to set up using traditional UK wiring (No Neutral at Switch). I am attempting to wire at the ceiling rose, utilising the available neutral. I have basically wired it as per his diagram attached, with the following amendments:
    1. No Bypass as I don't believe it's required if I have a neutral available
    2. The live to the light is wired directly to "O" on the shelly
    3. The supply Neutral is wired into "N" on the Shelly
    The problem I am having is that when the far switch is in 1 position, the first switch works, but when I go to change it, the first switch stops working. The Shelly always works as it should.
    What am I missing? It's been driving me up all wall all evening.
    Cheers
  • Are you sure the diagram is equivalent to the physical situation? All wires double checked? IMHO both switches should work as expected…
  • Hi
    I was 100% certain, but went to check anyway. It was 100% as per the diagram, however one of the switches is an outdoor switch with a small neon power indication light that ran between com and L2. This was throwing everything off. As soon as I took the light out of the mix, everything worked as it should.
    Have attached a picture of the type of switch just incase anyone else has an oversight like mine.
    Cheers 👍👍
  • Well done! For the records (chapter „lessons learned“) I would note that every detail in diagrams is absolutely necessary…
