how come the shelly1pm is getting warmer when the load increases. it is using a relay
  • Hello,
    i notice that the shelly1pm is getting warmer when turned on. not much because i have a small load.
    However i see people complaining that it is getting hot when a high load is switched, why is that?
    if it was using some kind of semiconductor it would make sense but the 1pm is using a relay and that one has very low resistance
  • Brilliant argumentation! But you ignored Shelly 1PM has an integrated energy metering, which uses a shunt resistor to determine the value of the flowing current. The more current, the more heat…
  • Aha. now it makes sense. lucky for me the load is max 20 watts(8 watt most of the time)
