rgbw2 switching on AC side
  • hi could someone explain what the device is that is connected between the switch on the AC side and the RGBW2 on the DC side . Is it an opto isolater and receiver /relay . Please also confirm the wiring as per the shelly diagram ? Is the AC switch just trigering the DC side ?
    Thanks
  • Indeed - the black device is an optocoupler which separates the safety-low voltage of the RGBW2 from the mains. Thus AC current flowing through the primary side of the optocoupler triggers via a photosensitive transistor the input of the Shelly, activating its function. And yes, diagrams in “lexicon” are applicable.
  • thank you for reply and confirmation does it matter which way the connections are made , is it the red and black leads on the low voltage side and the 2 black leads on the neutral mains side ?
  • Right: the side with the black and red wire is the low-voltage side. Here wire colours are essential! The other side with two black wires is the mains voltage side. The two black wires may be interchanged as appropriate.
