Hi there,
first of all, thanks for the great Shelly products! ![]()
I have 8 x Shelly 2.5 in place to automate rollershutter via Opnehab3, using the Astro Binding and the Shelly Binding.
The Problem: Shelly's are not visible (disconnected) in the Shelly App. It takes some time after some refreshs, that they occur properly in the app and that they can be controlled. If I connect from a browser directly to the fixed IP of each, the control works instantly! Unfortunately the shelly-binding in Openhab3 is losing the connection and crashes after some time...
Surroundings: Shelly Cloud is activated, latest firmware is installed, they all have a fixed IP via Shelly config and are prioritised in the AVM network setup. Wifi connection is via AVM Fritzbox 7590 and two Repeater 2400 and 1750E with MESH activated.
I believe that there is some correlation between the MESH network and the shlly protocol. Maybe some timeout between Router and Repeater, losing the connection?!
Many thanks for your support!!!
BR
U
