Switch input 4PM
  • Hi,
    I'm new here,
    I just received today my 2 4PM's and would connect my niko switches on it..
    But they are potential-free 24V push button N.O. (6fold or 4 fold)
    NIKO 170-60050 (https://www.niko.eu/en/article/170-60050)
    Is there any solution, how i can use them?
    *? can i use an phoenix contact? between the switch and the Shelly?
    this?
    I tought i just could replace my old Eltako esr12z-4dx-uc Teleruptors with a Shelly Pro 4PM.
    Greetings,
    Arvid C
  • Welcome to the Shelly Forum!
    And yes - you may use the Phoenix relays to bridge the voltage gap! But you’ll need a 24V DC power supply…
    Einmal editiert, zuletzt von thgoebel (25. Oktober 2021 um 22:59)
  • Another way to solve the issue would be to use two Shelly i3 to control the Shelly pro 4PM via DDD (“over the air”). This could be cheaper than buying 6 Phoenix relays. A 24V DC power supply to feed the Shelly i3 would be still needed (Caution: plus must be connected to blue wire of i3; minus to red wire; switch common to minus/red wire). You may find information about DDD in ‘lexicon’.
  • Don’t see any benefits deriving by usage of a Shelly pro 2PM! Except you need two Shelly pro 2PM for each Shelly pro 4PM. Sure - with Shelly pro 2PM circuit may be split on two mains phases. But this was not asked for…
