Hi
Hoping someone can help with the shelly dimmer 2 wiring please
I in the UK and have a standard rocker switch which has a neutral wire available and it will connected / powering a single 6w led bulb.
I cant work out if I need the wire both the bypass and the neutral in and if so how ?
I've found information that if you have a neutral wire you don't need a bypass, but if your powering under 10w (which I am) you do need a bypass.
I cant find a wiring diagram which uses both neutral and bypass
any help would be appreciated ![]()
