Roller shutter 2.5 don't close it
  • Hello,
    I have a problem with my shelly 2.5 in shutter roller mode.
    I carried out the calibration of the shutter, the shutter control is done by push buttons, an impulse on the PB for the descent, an impulse the other PB for the ascent.
    The shelly 2.5 is also associated with home assistant for automation.
    My concern being, mainly when closing the shutter only, I don't have the problem when opening.
    When I press the PB for closing or when it is time for the HA automation to close. I hear a pulse on the shutter, but it does not close .... And I have to press the closing BP several times.
    Do you have any idea 💡?
    Thank you
    Hi and welcome to the forum. :)
    more informations will be helpfull.
    Setup in HA?
    Setup Shelly?
    Firmware versions?
    Please have a look into our tips for beginners. (A6)
  • Hi 66er,
    Setup in HA?
    I use the schelly integration, automation is a follows
    For closing
    for Opening
    Setup Shelly?
    Power On Default Mode : ON
    Open / close working Time : 24 / 21, after positionning controls
    Input Buttons Mode : open & close - Use Seperate buttons for open & close
    Button Type : Toggle
    Mode : Rollers Schutter
    Firmware versions?
    20210720-184731/v1.11.0-g6abd92
    Thanks
    Regards
    2 Mal editiert, zuletzt von Karibou54 (28. Juli 2021 um 09:21)
