Pool Cover Shelly 2.5
  • Hi All,
    I'm looking for a solution to make my pool cover smart with shelly, i have an aquadeck ECB which is currently working with an key controller Open/Close see image.
    The board also has a pulse(4-2) on it which can be used with an eaton cSAu-01/04(Install manual)
    I was wondering if i also can use the shelly 2.5 for that? With the SW1 connected to 4 and SW2 to 2 and leave the O1 and O2 unused and at last connect the L and N to the same positions as in the picture to brown and blue.
  • silvertailke 23. Juli 2021 um 15:21
    Hat den Titel des Themas von „Pool Cover Shell 2.5“ zu „Pool Cover Shelly 2.5“ geändert.
    Hi and welcome to the forum. :)
    What is the grey device in your 2nd picture?
    What is the voltage to your switches? 230V ?
  • IMHO the grey device is an actor of EATON’s xComfort Smart Home Solution (click).
    Einmal editiert, zuletzt von thgoebel (7. August 2021 um 19:02)
