Which Shelly (1/2.5/PM/Dimmer/DimmerSL) can be used for situations without Neutral?
  • hi there,
    my first post in this forum. I hope I am in the right "section".
    I am doing some home automation here in Ireland. Typical wiring is similar to the UK, which means, switche locations usually are WITHOUT the presence of a neutral wire connection (phase L, switched L [to the bulb] and ground, but no N wire). Cables are laid into the wall "permanently", not like the Germany/Austrian system with conduits and junction boxes. So, "adding" a neutral without MAJOR refurbishment is not really an option.
    I am awaiting the release of of your Shelly Dimmer SL, which I believe, could be used in such circumstances.
    However, if I don't need a dimming function, just the ON/Off (actually, the dimming function would most likely damage the 230V non-dimmable LED bulb), what options do I have?
    1) Is there a Shelly on/off smart relay planned that will work without Neutral (similar to the SL Dimmer)?
    or
    2) Is there a way in the dimmer setup where I can "disable" the dimming function and only alternate between 0 and 100% power?
    THANKS
    Robert
  • Hello Robert,
    I believe Dimmer is the only device which would work with neutral and according to manual on Shelly homepage you should be able to turn it on and off without dimming. Well, this is jut theory, I am still waiting for the delivery.
    Btw: have you checked this thread already (I know its in German, but the connection scheme is self explanatory) - N-Leiter fehlt
    Hello @steirx and welcome to the forum,
    Shelly Dimmer SL is compatible with non-dimmable Bulbs 220-240V.
  • @greylisted,
    Danke für den Hinweis. Ja, diese Konstellation wollte ich vermeiden. Da wird immer wieder wer ausschalten und sich dann wundern, warum die "Automatik" nicht mehr geht ... (geht mir jetzt beim WC Licht schon so ...)!
    @MIHO:
    Danke! Wird es dann einen Parameter geben, der das Dimmen unterbindet?
    Laut Beschreibung;
    "AWARENESS: If the Device is not connected to the
    supported light types, the dimming functionality may not be
    present. However, you will still be able to turn on and off your
    lights." - erkennt das der Dimmer ODER muss/kann man das konfigurieren? Passiert das beim Kalibrieren ODER, wie ich fast vermute, Hier:
    "Transition Time
    Set the time (in miliseconds), for which Shelly Dimmer goes
    from 0% to 100%. The value can be from 0 to 5000 ms."
    Wenn ich den Wert auf 0 setzte, dann muesster der Dimmer ja immer von 0 auf 1 und zurueck springen!
    DANKE
    Gruss,
    Robert
    Mir ist keine Einstellung bekannt wo man das deaktivieren kann.
    Ich kann aber gerne mal übers Wochende mal nichtdimmbare Birnen verbauen und testen wie es funktioniert.
    Test Dimmer ist allerdings nur ein Shelly Dimmer (kein SL)
