Pin headers to fit the Shelly 1L ?
  • Hello
    I'm not sure if this is the right place to ask, but I couldn't find a more proper place, so I will just ask.
    I have several Shelly 1L's that I want to flush with Tasmota. I had success with OTA flushing with one of them, but the same process bricked two others so I stopped and went the serial way.
    I bought a usb to serial adapter as recommended in Tasmota website but I'm having trouble connecting it to the Shelly. I bought some pin headers like this but the distance between the holes in the Shelly 1L is smaller than the one of the pins. So I tried this but found out that the pins where too thick to fit in the holes.
    Have someone here managed to buy or make a decent pin header that can connect easily into the Shelly holes without the need to oprn the case and solder things ? If yes, can you please point me to where I can get them ?
    Thank you
    Guy
    It's from 2.5, I don't know if it's the same with the dimmer, just as an idea.
    Zitat
    The onboard connector is 1.27mm raster with 1mm diameter holes
