Separate RGB and White Led strips
  • Hi community!
    I would like to use a shelly RGBW2 with Alexa using the shelly cloud app (I already have other shellys)
    My plan is to use two led strips, one rgb for ambiance and a white one for illuminating a desk, and it is ok if only one of them can be on at a time.
    How do voice commands manage the white channel when setting a color?
    I am assuming that if I set a color different from white, the white channel will be off, and vice-versa if I set the light to white the RGB channels will be off. This would be an ok solution for me.
    Ideally I would like to control them as "separate lights" setting a color and a certain level of white. Is it possible to do that?
    Thanks!
    giukio
