Lost and confused.
  • Thank you for your patience with another first-time poster needing help!
    I have installed a Shelly1 onto each of my garage doors following this video guide. As seen in the attached picture, Kelly's garage door has a blue ring around the power button, whereas Ken's door does not. This power button has to be pressed once to remove the blue ring and then pressed another time in order to activate the door. Also, both doors have a reed switch installed (second attached picture), Ken's door will immediately close once the magnet influences the reed switch. This does not happen on Kelly's door. Finally, the wall switch for Kelly's door does not work; the light on the switch is off and the button does not operate the door.
    Again, thank you for your patience.
    Cheers!!
  • A couple things to try, In the Shelly app, go to the Timer and make sure you have an Auto Off set for 1 second. This may be why you have to press the button twice on your Kelly garage door module. Also go into Settings->Button Type and make sure both are set as a Detached Switch. It almost sounds like you didn't do this for your Ken module and the reed switch is acting as an actual on/off switch instead of a state sensor. As far as your non-functional wall switch, it sounds like you may have disconnected one of the leads when you were attaching the Shelly, so trace back the cables from the wall switch and ensure they are still firmly attached to the garage door opener. Finally go into Application Settings->Input State and check the button for Add input identifier so you can see the status of your reed switches in the App.
